What's the best set up for DC10 plus capture and editing? I have heard STudio 9 is best?
Has anyone here had positive results using XP, Studio ver 10 or later and a DC10 plus capture card?
Sony Handy Cam 8 MM analog is the source
Thanks!
I had a dc 10 plus like 4 years ago...it wasn't bad but there far better cards & cheaper now
I used to stay on studio 8 or virtual vcr. Virtual vcr is better if you ask me because you have the choice to not deinterlace but i remember that was a hell of a task to record with it because if i remember well the dc10 plus drivers are under the VFW norm which doesn't help.
And to edit well you edit with virtualdub mod or studio 8,9,10 depending of what you wanna make: divx,svcd,dvd etc..
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Miro DC10 + Fedora core 8
By bmw524 in forum LinuxReplies: 5Last Post: 7th Jul 2008, 07:28 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 10:02 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 22:48
