Can anyone recommend a good inexpensive core 2 motherboard, please. I just received a call from tech store that I need a new motherboard, I want to upgrade to the core 2 motherboard. Any suggestions. Thanks for any info, thanks.
newegg.com is the best place to check
be sure the PS can handle the neW MB
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2000200280+1070622729&name...EE+%2f+Pentium
Intel E4300 Core 2 Duo 1.8GHz Processor $113.50 Free Shipping -
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138034
I have this BIOSTAR mobo which is inexpensive and works well for me. I have a core2 duo E6400 processor w/2gb ddr2 pc677 kingston memory overclocked to 2.30ghz. I use this computer strictly for video encoding. If you're upgrading to core2duo processor you're going to need to upgrade to ddr2 memory w/a new mobo. There are some core2duo mobo's that can use ddr400 memory but it's wise to upgrade to a mobo w/ddr2 memory instead. That's my 2 cents!
A lot of people like the Gigabyte GA-965G-DS3 motherboards:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=gigabyte+ds3 -
Good point about the power supply. 450-500W or a little more is good. It's also nice to have one with the 24 pin ATX connector, but not required. But you do need the 4 pin CPU PS plug. A 450-500W PS or a little more is good.
Go with one of the major RAM manufacturers with a lifetime warranty, DDR2 800 should work well. RAM prices are fairly low at present.
I've also had good luck with the Gigabyte MBs, but shop around.
You should see a fair improvement with encoding times and multitasking with a dual core CPU and DDR2 memory.
That's the hot favorite ..............Originally Posted by jagabo
Thank you very much, I will be buying today a Gigabyte GA-965G-DS3 motherboard. Thanks again.
Motherboard for core i5
By themaster1 in forum ComputerReplies: 2Last Post: 6th Jan 2010, 16:50 -
Suggestion on motherboard for Intel Core 2 Q9650 Quad Processor
By G)-(OST in forum ComputerReplies: 11Last Post: 28th Jan 2009, 04:13 -
Intel Core 2 Quad 9550 or Core 2 Duo 8600 for games...
By retroborg in forum ComputerReplies: 11Last Post: 11th Oct 2008, 22:23 -
Intel Slashes Quad-core, Dual-core Processor Prices
By louv68 in forum Latest Video NewsReplies: 0Last Post: 22nd Apr 2008, 19:14 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 16:45
