Hi All,
I have a NTSC AVI clip that I ran threw Virtual Dub, to clean up. Now that I have the avi clip in Sony Vegas 7.0e, I want to export/render to mpg for DVD. I'm using the Debugframeserver to Cinema Craft Basic, and was wondering what colorspace is used for commerical DVDs? Cinema Craft gives me the choice of either RGB or YUY2. I know the video clip is in RGB but don't know if if it will show better on NTSC TV/LCD in YUY2?
Any suggestions?
Thanks.
Matt
I do have "Ignore Third Party DV codecs" checked, hopefully this is the same thing.Originally Posted by racer-x
Thanks.
Matt -
No, you want to Uncheck "Irgnore Third Party Codecs".
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
DVD like most distribution formats uses 4:2:0 (YV12) following the ITU-Rec_601 colorspace standards set back in the 1980's for 8bit and 10bit digital video. The analog YPbPr version is standardized in SMPTE-240.
This guy has a good overview description of the macro problem.
He leaves out the 0-255 vs. 16-235 luminance conversion issues.
http://www.animemusicvideos.org/guides/avtech/colorspace.html
It illustrates why an overall workflow needs to be designed. Programs like Premiere do a good job managing levels and colorspace from camcorder formats to DVD or ITU-601 even though internal processing is in RGB. Going out to external processing or import from need analysis and testing. I tend to favor empirical testing to ID problems with levels or color space. I use standardized test signals.
HDTV standards use the newer ITU-Rec709 YCbCr colorspace revisions that are better matched to modern displays.
Advanced discussions:
http://www.poynton.com/ColorFAQ.html
http://bssc.sel.sony.com/Professional/production/productsite/files/24PTechnicalSeminar3.pdf -
what colorspace to select in Lagarith ?
By codemaster in forum EditingReplies: 1Last Post: 1st Jan 2012, 09:44 -
colorspace conversation elaboration
By mammo1789 in forum RestorationReplies: 13Last Post: 18th Nov 2011, 13:36 -
Commerical DVD v/s DV->DVD quality difference ?
By Movie-Maker in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 14:21 -
Avisynth colorspace conversion - How to do it right?
By MagicSparky in forum Video ConversionReplies: 3Last Post: 24th Mar 2008, 20:28 -
DVD-R not auto expanding to 16:9 like commerical DVDs
By neilalp in forum Authoring (DVD)Replies: 5Last Post: 13th Feb 2008, 22:04
