When I loaded this video file in virtualdub I get this error http://i52.photobucket.com/albums/g13/chibi-pucca/vduberror.gif
then when I try to compress the audio it won't let me cause it came with a error showing this http://i52.photobucket.com/albums/g13/chibi-pucca/vduberror2.gif but I already have the codecs installed.
This is info about the video shown in gspot http://i52.photobucket.com/albums/g13/chibi-pucca/gspot1.gif
	Forget compression , set audio to full processing , then compression to none , save out as wav .
 Then under audio , sellect wav , locate the wav file just created , and now compression can take place .
 Failing that , give super a crack at it , its worked well on problematic clips .
  Need help with Audio stream format, VD/M won't compressBy talefing in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 13:22
  VirtualDub: "The audio codec cannot compress the source to the desiredBy user2008 in forum Capturing and VCRReplies: 6Last Post: 12th Jun 2009, 20:35
  Simplest and fastest way to compress LPCM audio to fit on DVD5By kurbads in forum User guidesReplies: 5Last Post: 18th Sep 2008, 04:15
  wmv encoding, cannot compress audioBy kidcash in forum Newbie / General discussionsReplies: 7Last Post: 27th Jan 2008, 15:58
  Does CloneDVD compress AUDIO too?By Serpeant in forum DVD RippingReplies: 3Last Post: 6th Aug 2007, 11:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
