Hi, everyone!
I'm stwbrysunshine and I'm new here and I've got a question: I've been making short films with USB, editing in Windows MovieMaker. I just converted to Firewire (yay) and everything's been going great until I started working on a new project, which is roughly an hour in length, unedited. The problem is, as I drag and drop each file into the storyboard window, each file becomes grainy and the sound quality sounds tinny and metallic. Is this something that will fix itself when I burn the project to DVD, or am I doing something wrong? Or should I just get a better program? Or recapture everything again? Any help would be greatly appreciated. Thanks!
Cheerfully,
strwbrysunshine
As long as your capture settings are set to DV-AVI it's an exact duplicate of what is on the cam.
ahhh, sweet.
i know i should test it...but how's this for fun: apparently my burner only came with a trial burning period and the actual pack is an extra 70 i don't have right now. (lame! a burner that doesn't really burn!)
thanks for putting my mind at ease! you guys rock! -
As far as the captured file goes you can use g-spot to determine what it is. Hard to screw it up with Movie Maker though cause you only have the choice of DV-AVI or WMV. You can also look at the file size, should be 13-14 gigs per hour. there's other software for trnasferring from the cam, WinDV is quite popular.
Originally Posted by strwbrysunshine -
just a guess, but it's probably the mpeg encoder that was a demo not the burning software itself. there are a few few encoders listed in the tools section. as for burning software you can't get much better than imgburn which is also available as freeware. may take a little time to learn but worth it.
if you need a free, easy to use encoder there is an old version of convertXtoDVD still listed.
http://download.videohelp.com/download/vsoDivxToDVD_setup_0.52.99.exe
may work for you.--
Originally Posted by aedipuss
Audio troubles, with firewire transfer from miniDV cam
By TheBigQuestion in forum AudioReplies: 29Last Post: 29th Sep 2011, 03:39 -
Questions about DV transfer and connectivity of Firewire/1394
By Movie-Maker in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 13:46 -
Firewire transfer from Sony HDR-HC1E
By Richard_G in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 26th Apr 2008, 22:21 -
Bland picture after firewire transfer?
By Jazzy78910 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 31st Dec 2007, 06:10 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 11:29
