Hi, I have a 1080i tv with DVI input only and no digital audio input/receiver in this room, Can I run a HDMI to DVI converter to my tv, but get audio through the composite output, or does this DVD player only run the audio through HDMI when video is output through it?
Also, If my tv doesn't support HDCP (I'm assuming it doesn't since its a few years old and only has DVI input) Will HDMI output not work at all for me? Or only upscaling on commercially released dvd's won't work as I've read on some sites.
My screen is only 30" so hdmi isn't a huge deal, I'm more interested in using the USB functionality here, so I can live without hdmi if need be. Thanks
It'll run throught the composite RCA outputs also, I do that to get my surround sound instead of using the outputs on my TV.
Dvi-hdmi audio question
By sanosuke in forum ComputerReplies: 1Last Post: 4th May 2011, 11:05 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15 -
Philips 5990: problem with direct connection to monitor via hdmi/dvi
By Rusty2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 11th Mar 2009, 23:50 -
best silent graphic cards with hdmi+dvi out and hdcp support
By deejay.2001 in forum ComputerReplies: 5Last Post: 13th Jan 2009, 15:01 -
Composite to HDMI/DVI/component Conversion
By Gromit137 in forum DVB / IPTVReplies: 3Last Post: 30th Oct 2008, 12:10
