I have some 320kbps mp3 files that were converted from .wav files which i no longer have.
I want to re-convert them to 128kbps mp3.
Should I just do a straight 320k->128k mp3 conversion or is it better to convert back to .wav then to 128k mp3?
I always thought that a high-to-low straight mp3 conversion is OK.
Thanks.
	In both cases it's decompressed and recompressed; just if you do it "directly" the intermediate is temporary.
	I recommend using WinLame to do the conversion. It can do entire folders and uses the best freeware MP3 encoder out there.
 MP3Gain is also a great tool that's worth looking in to.
	WinLame also uses the best known decompressor (MAD) internally working at 32-bit. Try to find RC3 version of WinLame, later ones are buggy. You can always update it with nLAME.dll of your choice (the best builds are 3.90.3 and latest 3.97).
	The Godfather also does batch conversions using LAME. Also a real good tag manager.
	Thanks for all the replies.
 So ANY app that will recode an mp3 will ALWAYS decompress the file then re-encode it again.
 What does it decompress it to? Its original format, or a "special" intermediate format.
 Maybe this is a dumb question, but my knowledge on the specifics is limited.
	Could be anything, but probably something like WAVE -- a lossless format.Originally Posted by tecstar
 If you look at Audacity's working folder when you open an MP3, you find it creating several huge files to work on, which it deletes when you close it.
 (There are also lossless compressed formats, like FLAC, but not a lot of software can handle them.)
 If you want to use an audio utility or editor that can't open an MP3, you make a wave file manually, which is almost universally useable. It's much larger, but there is no information loss.
  AC3 to MP3 Conversion / SynchronisationBy sjdean in forum Video ConversionReplies: 5Last Post: 18th Jul 2010, 21:25
  batch conversion of mp3 filesBy z999 in forum AudioReplies: 2Last Post: 14th Mar 2010, 14:33
  MPEG1 -> MP3 conversion possible in DOS?By Figge in forum Video ConversionReplies: 3Last Post: 25th Mar 2009, 09:05
  MP3 conversion analyzerBy zuja9 in forum AudioReplies: 4Last Post: 14th Feb 2009, 00:53
  XVID AC3 TO MP3 Conversion problem help!By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
