I'm having massive problems capturing from FCP HD Express. I get the "detected dropped frames" after few seconds every time/ every tape.
I'm plugged in directly to computer and even turned off preferece to abort on dropped frames!
Someone has suggested that going to 10.4.9 (which I did) could be problem. Can anyone help me here? I'm all out of ideas thanks.
Download and apply the OS 10.4.9 Combined System Update on top of your existing 10.4.9 System. There are times when the incremental system updates cause odd problems with Firewire and USB communications that are fixed when reapply the combined system update.
thanks Fro!
a new idea! Do you have a link for that?
is it simple to do?
VHS Capture my Mac?
By The Sumerian in forum MacReplies: 1Last Post: 25th Jan 2010, 12:17 -
Video Capture on Mac
By jonlesterwhite in forum MacReplies: 4Last Post: 29th Nov 2009, 05:41 -
HD capture with Mac G5 FCP 5
By artvesta in forum Capturing and VCRReplies: 4Last Post: 12th Jun 2009, 17:54 -
Use a MAC to capture...Use a PC to edit? Help!!!
By blainedepue in forum Video Streaming DownloadingReplies: 1Last Post: 27th May 2009, 03:43 -
DV capture on Mac
By thuriel in forum MacReplies: 11Last Post: 18th May 2007, 09:02
