I installed autoGK and it produces good video and sound but it is in black and white... What could be causing this?
The source are dvd vob files. If your talking about the greyscale option in the divx config zone options then it is not checked. I had to reload my PC and reload autoGK. I guess somthing is messed up although I reloaded the software after uninstall
Edit: When played on the PC using Media player -
I suppose you could have the Credits Greyscale Option enabled, and the Credits set to begin with frame #0:
http://www.autogk.me.uk/modules.php?name=TutorialEN#6
If so, uncheck the Greyscale and Encode Credits boxes. That's not a very likely scenario, though.
To confirm it's an encoding issue and not a player issue, open the AVI in VDubMod and scroll around. If you see color, then it's not AutoGK doing it.
Autogk Virtualdub AVS question.
By meneedit in forum Video ConversionReplies: 0Last Post: 9th Feb 2012, 04:31 -
AutoGK Question
By HamishT in forum Video ConversionReplies: 2Last Post: 5th Apr 2011, 22:53 -
A question (or rather questions) about autogk...
By neozeks24 in forum DVD RippingReplies: 6Last Post: 14th Feb 2008, 20:18 -
AutoGK conversion question
By Krispy Kritter in forum DVD RippingReplies: 13Last Post: 4th Feb 2008, 11:51 -
Question about AutoGK
By OzarkBaby in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2007, 14:50
