ive made a vcd, cut the vcd in half, first half great second half out of sync how can i repair it please![]()
get some strong glue (but I don't think a cut VCD and glued back can be played)
Why people don't read the guides? READ THE GUIDES!!!!! There are all there !
Generally speaking, you have to demux your second mpeg part and then demux it as VCD with audio or video delays.
You can use TMPGenc for de-mux and BBMpeg for re-mux -
IMPORTANT NOTE:
If you made a VCD with bitrate higher than 1150kbps it's going to be hard to get a perfect cut, if don't, try VCDcutter -
I agree. It's easier to use the Source Range filter when encoding than to encode the whole thing and then cut it. SatStorm is right on the money about having to demux and remux if you cut the movie after you've encoded the entire thing.
Pulling out my hair
By frostycarver in forum DVD RippingReplies: 2Last Post: 17th Oct 2011, 19:14 -
What color is your hair?
By johns0 in forum PollsReplies: 10Last Post: 11th Oct 2011, 00:53 -
How long is your hair?
By johns0 in forum PollsReplies: 28Last Post: 28th Nov 2010, 03:20 -
Grey hair - WTF?!
By Xylob the Destroyer in forum Off topicReplies: 21Last Post: 16th Mar 2009, 18:58 -
Authoring while tearing out hair
By GimpGuy2000 in forum Authoring (DVD)Replies: 3Last Post: 7th May 2008, 02:58
