What is a good program to use to convert files to high qualty dvd compliant mpeg files? I used to use tmpgenc 4.o express but since I upgraded to Vista from Xp when I try to run the program it says that some files are missing so I reinstall the program and it says the same thing?
I haven't had any problems with TMPGEnc Plus or TDA with Vista. But you could try the freeware HC encoder. But if you want a all in one converter, try ConvertXToDVD.
For other payware encoders, ProCoder or CCE are both faster than TMPGEnc. -
What format do those programs output files in because I files that I can put in Dvd lab pro?
something that doesn't take 7 hours for a 30 minute clip i suppose .... without much other info -- cant really give much more info
good program??
By rko2164 in forum Software PlayingReplies: 1Last Post: 22nd Dec 2009, 03:14 -
Does anyone know of a good deinterlacing Program
By jbandy1 in forum Video Streaming DownloadingReplies: 18Last Post: 16th Dec 2009, 11:50 -
A good and easy conversion program for Mac
By slackeer in forum MacReplies: 2Last Post: 24th Jun 2008, 08:41 -
Good dvdr program?
By chronic777 in forum Authoring (DVD)Replies: 20Last Post: 16th Aug 2007, 09:29 -
Good IM Program?
By Poppa_Meth in forum ComputerReplies: 11Last Post: 10th May 2007, 07:03
