Anybody used the alba dvd382stb? There available in asda for £40 and want to know if they handle dvd-r/rw disks ok?
Also if the can handle them is there a hack to get it region free?
Cheers for any help given.
A brief review where it states that it will play Region 2 discs. This suggests to me there isn't a hack. http://www.avreview.co.uk/news/article.asp?UAN=1092&v=1
However, for less money (if you get the tenner off by using Google Checkout) you could get one of these which is far superior!
http://svp.co.uk/products-solo.php?pid=2673
2 scarts instead of one, Region free out of the box, DivX playback and built-in card reader so you can view the pictures from your digital camera without having to download then first.
and a name that nobody is going to turn their nose up at either..... -
hi you wanted a hack for the alba dvd382stb
switch tv and dvd on with tray closed, press set up then 1-3-5-7 slowly,
left click arrow untill region appears set at 0
press set up and its done
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 11:44 -
Advice needed for Recording using Alba DVD recorder
By rhicel in forum MediaReplies: 2Last Post: 13th Mar 2008, 10:26
