i had an avi file which i convered to dvd using winavi... however i need to convert it back to avi... BUT their are 3 VOB files now.. how to i do this? i have virtualdubmod but the 'append segment' wont highlight. what am i doing wrong?
i opened up the first VOB... now how to get the other twon to join?
Extract the mpg from the VOBs with VOB2MPG.
/Mats -
virtualmod > tools > script editor .
Script for three vobs with 01 id's would be
vts_01_0.vob
vts_01_1.vob
vts_01_2.vob
Save as vts_01
Now open this file with vitualmod , it concats the files in order as listed .
The script should also reflect dirs , example c:\temp
c:\temp\vts_01_0.vob
c:\temp\vts_01_1.vob
c:\temp\vts_01_2.vob
Save as vts_01 in same folder .
Thats getting old , cant remember last time I did that .
VobEdit - won't join vobs
By bahjan in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2012, 19:29 -
help with virtualdubmod
By losernoob in forum SubtitleReplies: 7Last Post: 12th Sep 2011, 10:23 -
How to join 2 DVDs which results in more than 9 VOBs ?
By ffooky in forum MacReplies: 3Last Post: 11th Dec 2008, 16:19 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
Are you able to join PAL and NTSC vobs together?
By ramrod1234 in forum Authoring (DVD)Replies: 12Last Post: 26th Apr 2008, 04:27
