Hi All
A friend of mine gave me a CD with couple of AVI clips so I can use them with my school video project, but I can't open them, he told me I have to use a software called PICVideo, and I did but I keep getting a watermark on the clips, now my question is:
1- How can I open the Avi files without using PICVideo?
2- How can remove the watermark text on the clips?
3- Is their anyway I can convert them to other formats? then play them normally like any other clip?
4- Where can I find free clips on the internet?
Thank you in advance to all, and a spacial thanks to the owners of the website, this website helped me so much.
tyt
A winner is a person who asks questions and listens to the answers; a loser never listens. A person can run away from his troubles just as easily as he can run away from his shadow.
You could try SUPER to convert them to something else. It's free.
I guess it depends on what type of footage you need. Because good quality footage is expensive to shoot and store for download, most of it isn't free. A couple of places to look would be
http://www.archive.org/details/movies
http://search.creativecommons.org/Read my blog here.
Hopefully, the watermark is just with your version of PicVideo and not on the original files.
You have to purchase the program to eliminate it for the output files.
If you wanted to edit them, try VirtualDub or VD Mod.
For a good all-around video player that will play most anything and doesn't need installed codecs, try VLC Media Player. -
Tell your "friend" that using payware codecs like that isn't doing you a favor, and ask for them in a codec already licensed for use in Windows.
There is a wiki article on this codec:
http://en.wikipedia.org/wiki/MJPEG
You might try CamStudio to force capture while playing the avi. Turn off hardware acceleration before doing the capture.
Help with DVD clips TO AVI
By odiedog in forum Video ConversionReplies: 1Last Post: 10th Jan 2009, 10:13 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 13:32 -
Merging AVI Clips
By Soccerman77 in forum Video ConversionReplies: 3Last Post: 26th Nov 2007, 17:10 -
MPG clips to AVI
By Marcel555 in forum Video ConversionReplies: 2Last Post: 2nd Nov 2007, 18:07 -
How do i join 2 .avi clips?
By vandaLo in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2007, 21:52
