hi all.
i hope somebody can help me. i have several files of divX 511.AC3 which i need to reedit, but when i import into vegas, it shows only the video file. No audio is imported. vlc definitely plays the video and audio, so both tracks are obviously there, but why won't vegas?
am using vegas 7a.
thanks!
				Results 1 to 12 of 12
	I suggest using VirtualDub to save a WAV file of your audio and then import that separately. Watch out for synch issues. Even a broken clock is right twice a day.
	ok, virtual dub made a WAV copy of the audio track in stereo, but vegas won't recognise it. i've tried other WAV files in vegas, and they all work fine. vegas imports it to the project media bin, but won't allow it to be previewed, played or dragged to the timeline. any ideas?
	Did you drag it onto it's own audio layer? It won't overwrite your original audio. You have to mute the original audio track and place the WAV file underneath it on it's own audio layer. (unless you delete the orginal audio)
 You'll be playing two audio files at once. One muted and one not.
 Otherwise... make sure the WAV plays in media player. It should be a vaild WAV but make SURE.Even a broken clock is right twice a day.
	VirtualDub:
 File -> Open Video File
 Audio -> Full Processing Mode
 File -> Save WAV
 Otherwise you'll get AC3 in a WAV container.
	I have found, at least with virtualdubmod, that you should also click on Uncompressed PCM to make sure you do get what you think you are getting Read my blog here.
	ok, tried g-spot, yes its an ac3 in WAV container. (thanks for that tip!)
 then, followed jagabo's instructions, only for vdub to tell me "no audio decompressor can be found to decompress source audio format". is there some kind of ac3 codec plug-in for vegas, virtualdub or another standalone decoder?
 i'm using virtualdub 1.6.18.
 thanks for all this help everybody...
	AC3 ACM Decompressor or AC3filter should do the trick for virtualdub Read my blog here.
	haha... it works!
 after installing ac3 acm decompressor, vegas suddenly recognises the audio track of the divX and now plays both the video and audio. thank you all for your help. much appreciated, hope i can return the favour someday...
  Vegas image issuesBy SKU in forum EditingReplies: 0Last Post: 29th Jan 2012, 19:13
  Sony Vegas 8 issuesBy sapph13 in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2010, 16:27
  Sony vegas issues?By islandstyle in forum Newbie / General discussionsReplies: 1Last Post: 2nd Apr 2009, 03:38
  Problems encoding from Vegas to Divx and AC3By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 05:30
  Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
