Results 1 to 9 of 9
  1. Anonymous
    Guest
    I burned a DVD of the kids play using Pinnacle Studio 8.
    It worked on the computer and DVD player.
    I wanted to make copies for their friends so I used Nero 6.6.1.4 to copy the DVD.
    The copies work in the computer, but not on the DVD player.
    First I suspected bad disc's, but this has happened more than once.
    I end up burning the DVDs from Pinnacle, but it's not as fast.
    Any ideas on what could be causing this?
    Thanks.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    what brand of dvd media are you using?
  3. Anonymous
    Guest
    I am using NexXtech DVD-R 8x 4.7GB.
    When I use the same media from Pinnacle Studio it works.
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Nexxtech media id is CMC which is crappy low grade media. Try using VERBATIM dvd media and use IMGBURN to burn.
    http://www.imgburn.com/
  5. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Originally Posted by videohelpmaster
    dvd cann't copy, because of copyright.
    the OP made a dvd of his kids playing. higly doubt it is copyrighted. read the post correctly. :P
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Besides using good media also be aware that some players aren't compatible with +R or -R discs. Look your player up by clicking the link on the left "DVD Players".
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Best way to make a 1:1 copy of a home made DVD is to use DVDDecrypter, ISO read, ISO write.
    /Mats
  8. Anonymous
    Guest
    Thanks, I'll give those two a try.
  9. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Also consider that some older players are not compatible with any burned disks.
    Many people have good results with CMC media, and it is used by better known brands than Nexxtech. But some writers and some players cannot tolerate it.
    If burning from Pinnacle is successful, but your copies are not, it is possible that the player is enforcing what it thinks is the DVD standard on the disk and decided it is not complient. Unfortuantely this is common on certain older, expensive players.
