Hey,
Just curious about possible settings you guys use when capturing, so answer these questions :P
(assume these questions are for capturing to VCD)
1. What program you use for capturing? AVI_IO
2. What codec you use for capturing /& settings? Pic Video codec/ quality @18, sometimes 20.
3. What resolution do you use for capturing? 352x288 @ 25fps
4. What filters if any do you use? if using VDub I use 'Blur More'.
Hi,
I use VDub at 720x480 with Huffyuv compression, default settings, no filtering, audio 44.1 Khz.
It gets about 30GB per hour
PCTV
Celeron 766@862
128 RAM
Asus P2-99
GeForce2 -
Hi,
I capture with VDub at 720x480 (YUY2) for SVCD or 704x576 (YUY2) for VCD using Huffy at whatever default settings are. Since Im in the UK I always capture at 25fps.
I dont use any filters while capturing though when its done I either run it though a temporal smoother (5) and then sometimes dynamic noise reduction (orig, 6) depending on how it looks.
Im also playing about with AviSynth using GreedyHMA and MPEG2Dec, havent done much with it yet but think its what I'll use in the future, like what I've seen so far.
Cheers
MaSo -
Hi,
For my editing projects that I usually convert to VCD or SVCD I capture identical to dvbr :
VDub at 720x480 29.97 fps with Huffyuv compression, default settings, no filtering, audio 44.1 Khz.
If I am just capture straight to VCD from DVD or TV, I use MMC with the help of Stinky's Reg Tool.
TheNob -
I capture right to mpeg-1 with my radeon 7200 VIVO at 352x240 by 2.0 kbit/sec. I then edit with vcdcutter4.04 and then multiplex with tmpgenc. i hate the whole process of converting.
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 11:13 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
external USB HDD and standalone player Survey
By nalooti in forum Portable VideoReplies: 0Last Post: 18th Dec 2007, 05:30 -
Survey about future features in Adobe Encore
By EncorePM in forum Authoring (DVD)Replies: 0Last Post: 27th Aug 2007, 16:13 -
CD Freaks ANNOYING BLOODY SURVEY POPUP
By Anonymous4374945 in forum ComputerReplies: 16Last Post: 18th Jul 2007, 19:43
