I was just talking to a friend that suggested to me since I wasn't using my iPod on my tv, to resize the movies I've bought from iTunes from 640 width down to 320, in an effort to reduce the file sizes of the videos. These videos are all in m4v format. What can I use to do this?
I've done alot of searching on google and other websites, and I can't find much on converting m4v's. Maybe I'm looking in the wrong places.
M4Vs are actually just MP4s - Apple uses different extensions to differentiate between the streams a little better. (...such as M4A = audio stream, M4B = audiobook, M4P = protected audio stream, as I recall. Though, I may be wrong.)
The primary problem is, however, that since you bought the videos from the iTunes music store, they're encoded with DRM - meaning that you have to get rid of that before you can even think of converting or re-encoding, and I don't think there's anything really available at the moment for videos bought from iTMS.
Of course, converting or re-encoding the videos will mean they'll take a quality hit, too.If cameras add ten pounds, why would people want to eat them? -
iSquint would probably have the same problem with DRM video from the iTMS. It appears to mainly be a converter for videos into iPod formats. (I haven't tried it on my Mac, because my iPod is an older 4G (no video support), and likewise, I haven't had much reason to buy videos from the iTMS.
My sister does have a 5G video iPod, however.)
If you're looking for converters to convert videos to iPod formats, however, there are a number of them for Windows as well as the Mac. On the Windows side, I've tried both SUPER and Videora iPod Converter, and the latter's worked the best for me (though I haven't tried the new 2.x overhauled versions, yet.)If cameras add ten pounds, why would people want to eat them?
iTunes videos .m4v choppy, hangs up
By hollowman in forum Newbie / General discussionsReplies: 0Last Post: 1st Sep 2009, 06:16 -
a few m4v files have no audio when playing in iTunes...work fine in qt/vlc
By bobogs in forum DVD RippingReplies: 0Last Post: 18th May 2009, 21:21 -
Changing resolution without reencoding
By hanugro in forum Software PlayingReplies: 10Last Post: 7th Apr 2009, 22:28 -
Changing Resolution Undesirably?
By hamid22689 in forum DVD RippingReplies: 7Last Post: 26th Sep 2008, 13:02 -
Changing Video Resolution
By Erf in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 23:16
