Sorry for the other post that i posted that day![]()
Well Lets get to the tutorial!
the programs you need are AVS Video Converter (not free) and a different converter that does the same thing like rmvb to avi that you thought couldn't work and also download real alternative just in case.
the reason why to use two converters is that AVS has the RV40 codec in the programming of the conversion software. So AVS foolishly left the codec to the open for other programs to use it. AVS Uses Realalternatives codecs on their program so thus leaving it out.
Avs Leaves a water mark on the video in the center becuse its not free.
Install Both converters in the machine and use the other converter you downloaded and not AVS.
On the other converter do the converting settings normally and There! Your RMVB become AVI encoded with Xvid or Divx which ever is fine.![]()
Here Are the different converters you can use
-imTOO
-free ipod video converter (only for iPod users)
-Super
-Quick Video Converter (poorly converts)
etc
Research Done By RealMix .Inc
The only RV40 decoder is from Real. AVS, Real Alt, etc. just bundle it.
If you have downloaded Real Alt then I am unsure of why you would need AVS Video Converter if you aren't actually going to use it for converting. Real Alt installs Real's decoders along with Gabest dshow splitter. Should allow any dshow based converter to convert rmvb files. -
o ok i did that without reAL ALT and it worked but it sometimes dont work so i thought to put that on
REALMIX CODECS
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 20:56 -
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:09 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 11:29 -
What program will convert AVI to .RMVB quickly?
By Salva Veritate in forum Video ConversionReplies: 8Last Post: 13th Aug 2007, 22:15 -
THE BEST POSSIBLE WAY TO Convert RMVB TO AVI WITH VIRTUALLY NOTHING!!!
By RMVBMASTAPRO in forum Video ConversionReplies: 3Last Post: 26th May 2007, 03:07
