Ok, this is the problem that just started occurring for some reason. I'll be on the computer and everything will be running smooth and then when i start opening up more programs or watching videos the computer will just shut down by itself. If i turn it back on it was say overclocking failed as far as i know i havent touched with that. so i need some ideas to why this may be happening. thanks Scott
Couple of things that spring immediately to mind are :-
Virus -
CPU fan -
Faulty Memory -
Faulty Power Supply -
Fisrt 2 are easy to check - run a full scan using your AV software and take the cover off your machine, power it up and check all the fans are spinning and shifting a sensible volume of air. With the machine powered off it might even be worth cleaning the dust out of there (using a plastic nozzle).
Faulty Memory is much harder to test - I found this http://www.majorgeeks.com/Microsoft_Windows_Memory_Diagnostic_d3955.html which may be able to help
Failing power supplies have so symptoms that I tend to change the PSU when I've eliminated other causes.
If you have a PC Health monitor you could run that and see if it shows any problems just before failure - such as the line voltages dropping which would indicate a PSU which is underpowered or failing.
Anyone got any other ideas? -
Hey I installed a Probe software that test my computers performance. It states that my CPU temp is 2 high. so i cleaned my cpu fan out, (had lots of dust in in) and keep my computer off a while to cool it down. restarted and still saying its 2 hot.
If the CPU is running hot then it's odds on the fan is not shifting enough air
Simple job to replace - although you'll almost certainly need to replace the heat exchanger and fan as a single unit. -
time for a new coat of thermal paste on that cpu and maybe a new heatsink fan.
just fyi, sounds like the power supply may need cleaning as well
did you buy this machine new?
the emergency cutoff is Russian roulette- you may lose a HD or the mobo itself if it keeps happening...
Major synchronizing problem please?
By tendra in forum Video ConversionReplies: 2Last Post: 31st Aug 2010, 11:28 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
Major Encore Menu Problem!
By RealitySets in forum Authoring (DVD)Replies: 3Last Post: 3rd Sep 2007, 17:53 -
Major 'Codec' Problem
By mattstan in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 15:18 -
Major Problem with AVI
By thepcpitstop in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 6th Jul 2007, 11:49
