hey, I was just wondering what's a good type of harddrive to get? and what does all that ATA 100, ATA 66 stand for?
and what's a good seek time I should look for in hard drives?
thanks
If you want to understand what people are talking about when they recommend you an ATA100 7200rpm etc. I would suggest you visit
http://www.howstuffworks.com/hard-disk1.htm
for a general overview. Your more indepth and specific questions can be answered in the Q&A section here:
http://www.howstuffworks.com/framed.htm?parent=hard-disk.htm&url=http://www.cis.ohio-s...part1/faq.html
When using for capturing, your best choice would be using SCSI-IIIuw (disks going over 10000rpm) and if possible, configured into RAID-5.
But because only big company's can afford this, for consumer I would suggest to get a fast system with onboard ATA-100 IDE's. Currently there are disks (IDE) available at 7200 rpm (ATA-100), which are extremely fast (so best choice for home-capturing). Be sure, if you're going to buy them, to get disks at high of possible sizes (I've got 1x40Gb and 1x60Gb = just good enough for extremely capturing).
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
