  1. I was creating a menu with dvd-lab pro but i happened to find out that it is very limited (at least in my opinion....) How do i create those animated buttons (like those few that came with the lab)? And how do i export from DVD Menu Studio to DVD-Lab Pro, is there any way?
    One last question ^^ If i create a flash animated button, when i convert it to a video file, it will still have the animation effects of mouse over and etc?
    Please, help (adopt) a newbie ^^
    Thanks in advance, and keep the good work with the guides...
    Paul.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Lab Pro is only limited by the user. The software itself is about as powerful as you can get for DVD authoring without selling your car to buy it.
    No authoring tool creates animated buttons because the DVD spec doesn't allow for it. They have to be faked using a mixture of motion menus and switched menus. Both are covered at the link post above.
    Read my blog here.
  4. Thank you ppl ^^
