    May 2007
    Australia
    I want to convert my recordings to a decent size for torrents
    I have had the luxury of enjoying many shows and I would like to return the favour
    I have done much research and have searched this site and the internet but have yet to find a succinct guide
    A 40 minute show usually ends up being about 350 mb
    I can't get my recordings this small
    I have various options of recording
    dvd recoder
    hd digital tv tuner card
    topfield
    I use VideoRedo often
    I guess it's just the settings but I would love a succinct guide that explains how to get a 40 minute programme down to a 350mb avi file
    any help would be appreciated
    USA
    damodags, one post per subject is enough. I have deleted your other post. Please read our rules before posting.
    Moderator redwudz
    Try WMV or MPEG 1 if you want a fairly universal format for web video.
    Jan 2007
    first you capture/record it 'the best you can do' file size will be BIG
    then you use one of the available conversion/encoders to convert it to VBR Xvid or dviX at the appropriate reduce resolution
    thats how you get it down to 350 meg
    personally i prefer higher quality like 700 meg per 42 mintues of TV series
    Use AutoGK and convert to avi xvid.
