Ok I ripped some scenes from dvd's useing dvdshrink. Now I want to put them on one dvd with a simple menu. Seems Tmgenc DvD Author works the best. But for some reason it says this dvd's bitrate is to high on title 1. Doesn't matter if I remove title one and replace it with a different scene it says the same. I ignored it twice and ended up with unreadable discs.
Every other program out there loads the files fine and burns them fine and they play fine. I don't understand why tmpgence is giving me these errors, they come straight from disc that plays fine in my standalone and was straight ripped no encoding etc. It's just the other programs won't load up my whole scene it will split them at each VOB and make a like 3 preview screens on the menu. I only need one for each scene. Tmpgenc tells me I need to reauthor them which is crazy the play fine in a standolone. Not one other programs has given me these issues about the dvd bitrate being to high etc. And it only complains about title 1. I could switch title 2 to title 1. It would still says title one bitrate is to high non compliant dvd blah blah.
Can anyone recommned a good program for me to use for this that is simple like Tmpgenc but does throw out these errors that I'm expircening. Thanks
Some encoders do not correctly write the bitrate into the mpg header. Tmpgenc doesn't actually check the bitrate, it just reads the header, and sometimes gets it wrong. Extract the mpg from the VOBs using VOB2MPG, then rewrite the header with a lower bitrate value using DVD Patcher or ReStream.
Read my blog here.
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Problems Creating ISO with DVD Fab Decrypter
By ViRaL1 in forum DVD RippingReplies: 1Last Post: 25th Jan 2009, 12:30 -
Problems creating DVD from Vob files
By 1234567 in forum Newbie / General discussionsReplies: 16Last Post: 21st Dec 2008, 15:43 -
Problems creating DVD from Shaw Cable Motorola DCT64616 III transport strea
By Mendel in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 7th Feb 2008, 09:45 -
Making a comp and having some problems need some expert help
By moviedude2525 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2007, 17:03
