I have bought an LG RH188S and initaily everything worked great.
However, for some reason, now whenever the DVD recorder is turned off, the TV picture goes black & white. I also have a freeview box, and both are connected via SCART leads.
Any help or suggestions appreciated.
Blame the French for SCart.
Find a way to connect the TV to the source separate from the DVD recorder or don't turn off the recorder. -
The thing is, this definately did not happen when we first installed the DVD (2 months ago).
I've checked the SCART connections - they seem good.
Wondering if there is something in the DVD setup that has changed, but I havn't been able to find it yet. -
Check to see that your connection uses the pal format instead of ntsc. Maybe your recorder does ntsc to pal conversion.
The recorder is a PAL system for the UK so I don't think that is the issue but thanks for the suggestion.
Like I say, this was working great out of the box - the black and white thing only started after a few weeks.
It's a pain because it's easy to forget to turn the DVD recorder off at night, and also we need to turn it on even if you only want to watch TV via the freeview box - otherwise you are stuck with B&W. -
Check the output format settings for both the recorder and Freeview receiver. An S-Video signal into a composite video input will give a black and white picture. Ideally set the output format on both units to RGB if it is available. Most Freeview boxes will output either Composite or RGB, most DVD players will output S-Video as well. I suspect you've got the recorder set to S-Video.
AVI to DVD Loses a Few Frames
By BinaryRock in forum Video ConversionReplies: 0Last Post: 28th Jan 2010, 17:56 -
MKV to DVD -- audio loses sync
By Dr.Rock in forum Video ConversionReplies: 15Last Post: 30th Aug 2009, 03:51 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 22:03 -
dvd flick turned my iso into a winrar...
By weezie1920 in forum Video ConversionReplies: 2Last Post: 8th Nov 2008, 10:02 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
