I have an HP pc that has the dock for an HP Pocket Media Drive.
1. Does anyone know what type of drive fits in this enclosure? (It's not the Personal media drive it's the Pocket Drive) Perhaps a laptop drive?
2. Does anyone know how to open it up and replace the existing HDD?
What We Do In Life, Echoes In Eternity....
Take a look here: http://thegreenbutton.com/forums/2/187089/ShowThread.aspx They seem to have the methods there for opening them.
There appears to be more than one model. They may apparently have a 3.5 or 2.5" drive, PATA or SATA depending on the model.
But you may also be able to use just a standard USB external hard drive if you just need more space. -
I already have 3 external drives. I was thinking that if I can find a cheap used pocket drive or even an empty case, then I could just add my own larger drive. My HP PC has a built in slot for the pocket drive. If I can't find a cheap pocket drive around, I'll probably just remove the pocket drive chassis from the case and add an internal drive there for more space.
What We Do In Life, Echoes In Eternity.... -
Well my idea to buy a dead/bad pocket drive is now over. Contacted HP and they said that there is no way to replace the drive if it were to fail. Of course this could be them saying that so you'd buy a new one instead of replacing it cheaper.....Until I find more info about the possibilites of replacing a dead drive. I'm out of the pocket drive game.
Opening the HP Pocket media Drive is as simple as peeling back the hardened plastic label on the usb connection end and removing the two small phillip head screws hidden there. Once the screws are removed the drive carrier will slip out the front of the enclosure and the hard drive can be easily replaced.
Lee A -
eaudirsc, you are my god! How not to think about that! Now I can put 500 Go in my HP Slimline 3305.fr. Waiting for 1 To 2.5" hdd!!!
Merci beaucoup!
All the best!
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 11:33 -
What can I replace a Mitsumi DD floppy drive with?
By piano632 in forum ComputerReplies: 8Last Post: 19th Dec 2008, 09:00 -
Question about how to replace internal hard drive
By jimdagys in forum ComputerReplies: 2Last Post: 21st Apr 2008, 12:22 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58 -
What type HDD to replace a HP Pocket Media Drive?
By Denvers Dawgs in forum ComputerReplies: 4Last Post: 6th Jun 2007, 17:32
