I've created a SVCD from my DV camera. The settings I've used in CCE SP 2.62 are CBR 2580, Luminance 0-255.
The SVCD is good (a little bit better than tmpgenc) but in the fast scene the video is not very fluid. I've tried to change the parameter "quality priority" from 5 to 23 but the results are similar.
It seems that the codec give more priority to the picture quality (respect the frame rate). So when the camera move quickly the MPEG become not fluid.
What settings I've to use to avoid this problem ?
Many thx in advance for any help.
A) Dont double post
B) Use at least 3pass VBR instead of CBR, set image quality to 0, and set bias to 0 as well -
sorry for the double post.
Thx for your answer, I have some questions about.
1) Given that my DVD player read at 2x and CBR 2580 is the max bitrate possible, what benefits involves the VBR for the quality ?
2) Why the parameter quality priority set to 0 improve the quality of the movement scenes ?
3) Where is the bias parameter ?
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
Cinemacraft Encoder..Black void after encode
By Soixante in forum Video ConversionReplies: 6Last Post: 28th May 2008, 04:43 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 18:30 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 13:53 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27
