Hi, I recently moved to the States and took my almost brand new DVD Recorder. It is a Sony RDR-HX725. I solved the "Power"-Problem, but can still not figure out how to set it up. It seems not to work. Can anyone give me a hint on how to set up that DVD Recorder to my US Cable Box and TV? Or does a European DVD Recorder does not work over here?
I have a Codefree Recorder!
I would appriciate any help that you can give me!
Thanks a lot
European DVD recorder is PAL. USA is NTSC. Your recorder will not work in the USA. Sorry....
You may be able to record with the RCA/Cinch connectors....but you wont be able to use the tuner. I'm not sure if Sony's can record both NTSC and PAL.
I have an American DVD Recorder here in Germany and I use my VCR tuner then out to my DVD Recorder....but my Philips can record in both NTSC and PAL....but not with the tuner.
Will region 1 (usa) dvd play on my dvd recorder
By ag251148ws in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2012, 12:41 -
Recommendation wanted for DVD recorder in USA
By jman98 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th Jul 2011, 13:46 -
No Subsciption-free DVR + DVD-Recorder Combo in USA???
By mltwitz in forum DVD & Blu-ray RecordersReplies: 35Last Post: 13th Jan 2011, 23:23 -
Looking for good DVD recorder to work with HF200
By kritayot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Jul 2009, 18:55 -
Will this cable work to connect my Epson S3 VGA port to aHDMI DVD recorder?
By NG in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2007, 00:20
