Hello,
I have Sky + and I have a few shows recorded in my Sky Planner, I wanted to record 1 of them onto my pc (or mac). Is there like a simple wire i can connect to my pc and the sky box? I don't want to watch sky on my pc or anything i just want to record the program i have saved in my sky planner.
I've been searching the internet but i coundn't find anything, what i was hoping for is a little program i can run and a wire to connect the pc and sky box then just play it off my sky box and record, without the need for tuner cards and those sort of stuff.
The sky box on the back has got RS-232, S-Video, Left+Right Audio Out and a free Scart Lead bit. Duno if that helps![]()
So...erm hopefully somebody can help me.![]()
You can't do it without a tuner or capture card. It is simply a case of running a wire (well, 3 actually) from the Sky + box to the computer but, without a tuner or capture card, you've got nowhere on the computer to connect the wire to.
I just googled it and i found that I do have one of them lying around somewhere a Hauppage 1 or something. Do you know what wire(s) i need to get?
If the Hauppage can accept S-Video, you'll need an S-Video cable and a twin phono cable for the audio. If it can't take S-Video, you'll need a scart OUT to 3 phono (yellow, red and white) to connect to a composite video input.
Sky+ HD to PC
By BIGD22 in forum DVB / IPTVReplies: 4Last Post: 27th Sep 2011, 14:59 -
Any way to record from my Sky HD box? through AV or HDMI?
By gretaro in forum DVB / IPTVReplies: 2Last Post: 9th Apr 2011, 15:08 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Record from Sky+
By village56 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2007, 13:24 -
I want to be able to record Sky TV to disc?
By Gun in forum DVB / IPTVReplies: 2Last Post: 11th Sep 2007, 04:13
