ive gone through some posts but it all gets too complicated
basically, im looking for the best easy to use converter from avi-dvd-r, but where ti gets complicated is
it is a 10 inch portable dvd player, is 350mg avi going to look the same as 600mg avi
lastly, how much space on a dvd-r do 350mg and 600mg avi's take, both are about 42 mins long
ConvertXtoDVD.
Usually is bigger file size better quality if it's same video codec but convert from the avi that looks best. And the space on the dvdr depends on what video bitrate you choose when convert to dvd(42 min about 1.5-2gb). ConvertXtoDVD will automatically calculate the video bitrate for you.
Rendering options
By MBS in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2010, 11:17 -
mkvmerge options
By magmo in forum Blu-ray RippingReplies: 3Last Post: 20th Jul 2009, 09:58 -
VOIP - If You Want It, What are The Best Available Options?
By Frank-0-Video in forum ComputerReplies: 3Last Post: 1st Mar 2009, 09:56 -
Is there any player with these two options together ???
By moiz in forum Software PlayingReplies: 3Last Post: 2nd Nov 2008, 00:01 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
