Hi, I have an NEC 2500a dvd burner and it used to burn DVD Video Files just fine and one day it stopped. Everytime I try to author a DVD vidoe in nero, or try to backup a dvd with DVD shrink it gets to between 18%-90% and then has errors.
I have tried updating the firmware, enabled dma, and a few other things I have seen mentioned on thread here. I have reverted from Nero 7 to 6.6.0.13 still with no luck.
Can someone please help me? Thanks!
Below is my error log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 6:35:34 PM
Nero API version: 6.6.0.13
Using interface version: 6.0.0.0
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 13c
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.0B - HA 3 TA 1 - 6.6.0.13
Adapter driver: HA 3
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : ST380011A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8162B atapi Port 3 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 3 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVD-ROM GDR8162B D: CDRom0
_NEC DVD_RW ND-2500A E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1021MB (1046252kB)
Free physical memory: 642MB (657792kB)
Memory in use : 37 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
26.5.2007
NeroAPI
7:03:00 PM #1 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
7:03:00 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
7:03:00 PM #3 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-2500A running
7:03:00 PM #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
7:03:00 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
7:03:00 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3293
7:03:00 PM #7 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-At-Once, using DVD media
7:03:01 PM #8 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2202159 (489:22.09, 4301MB)
7:03:01 PM #9 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO
7:03:01 PM #10 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
Disc Manufacturer: TTH02 -
Disc Application Code: 64, Disc Physical Code: 193
7:03:01 PM #11 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
7:03:01 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2202160 (2202160) = #2202160/489:22.10
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2202160 blocks [_NEC DVD_RW ND-2500A]
7:03:01 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4510023680, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2202160 | lead-out | 1 | 0x41 | 0x00
7:03:01 PM #14 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
7:03:01 PM #15 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
7:03:01 PM #16 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
7:03:01 PM #17 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 8x (11,080 KB/s)
7:03:01 PM #18 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
7:03:01 PM #19 Text 0 File DVDR.cpp, Line 2267
Recording mode: Sequential Recording Mode
7:03:01 PM #20 Text 0 File Mmc.cpp, Line 21469
Set BUFE: Buffer underrun protection -> ON
7:03:01 PM #21 Text 0 File DVDR.cpp, Line 2421
Start write address at LBA 0
DVD high compatibility mode: Yes
7:03:01 PM #22 Text 0 File Cdrdrv.cpp, Line 8438
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
7:03:05 PM #23 Text 0 File Cdrdrv.cpp, Line 1288
19:03:05.156 - _NEC DVD_RW ND-2500A\H3 T1 : Queue again later
7:06:19 PM #24 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 3, TA 1, LUN 0, buffer 0x00C80000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x06 0xE6 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
7:06:19 PM #25 CDR -1135 File Writer.cpp, Line 311
Write error
7:06:19 PM #26 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
7:06:19 PM #27 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
7:06:19 PM #28 Text 0 File DVDR.cpp, Line 2658
EndDAO: Last written address was 452191
7:06:19 PM #29 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 8x (11,080 KB/s)
7:06:19 PM #30 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
7:06:19 PM #31 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/10/2006 12:42:42 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.41a, size=36560 bytes, created 28/09/2006 7:53:22 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Thank you for your reply Baldrick, I tried imgburn as you suggested and had no errors while using it in test mode.
However when I tried to actually burn the DVD the first error that appeared was this:
I clicked try again and same error came up so i tried to continue and they same error came up with the last digit of the sector number incrementingI/O Error!
ScsiStatus: 0x02
Interpretation: Check Condtion
CDB: 28 00 00 1D 3D 10 00 00 01 00
Interpretation Read(10) - Sector: 1916176
Sense A: F0 00 03 00 1D 3D 10 0A 00 00 00 00 11 00 00 00 00 00
Interpretation: Unrecoved Read Error
The error log had the follow output.
I 21:25:23 Image File: -==/\/[BUILD IMAGE]\/\==-
I 21:25:23 Image File Sectors: 2,201,904 (MODE1/2048)
I 21:25:23 Image File Size: 4,509,499,392 bytes
I 21:25:23 Image File Volume Identifier: testdvd
I 21:25:23 Image File Application Identifier: IMGBURN V2.3.2.0 - THE ULTIMATE IMAGE BURNER!
I 21:25:23 Image File Implementation Identifier: ImgBurn
I 21:25:23 Image File File System(s): ISO9660, UDF (1.02)
I 21:25:23 Verifying Sectors... (LBA: 0 - 2201903)
W 21:45:30 Failed to Read Sector 1916176 - Unrecovered Read Error
W 21:45:30 Sector 1916176 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:37 Failed to Read Sector 1916177 - Unrecovered Read Error
W 21:45:37 Sector 1916177 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:45 Failed to Read Sector 1916178 - Unrecovered Read Error
W 21:45:45 Sector 1916178 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:47 Failed to Read Sector 1916179 - Unrecovered Read Error
W 21:45:47 Sector 1916179 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:48 Failed to Read Sector 1916180 - Unrecovered Read Error
W 21:45:48 Sector 1916180 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:50 Failed to Read Sector 1916181 - Unrecovered Read Error
W 21:45:50 Sector 1916181 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:51 Failed to Read Sector 1916182 - Unrecovered Read Error
W 21:45:51 Sector 1916182 maps to File: VIDEO_TS\VTS_01_4.VOB
W 21:45:53 Failed to Read Sector 1916183 - Unrecovered Read Error
W 21:45:53 Sector 1916183 maps to File: VIDEO_TS\VTS_01_4.VOB
E 21:45:54 Failed to Read Sector 1916184 - Unrecovered Read Error
E 21:45:54 Sector 1916184 maps to File: VIDEO_TS\VTS_01_4.VOB
E 21:45:54 Failed to Verify Sectors!
E 21:45:54 Operation Failed! - Duration: 00:20:31
I 21:45:54 Average Verify Rate: 3,115 KB/s (2.2x) - Maximum Verify Rate: 10,262 KB/s (7.4x) -
What is TTH02 media. Can't find this mediaID in the lists on this site.
Is this what you have used in the past? -
TDK - link below:Originally Posted by oldandinthe way
https://www.videohelp.com/dvdmedia/tdk-dvd-r-tth02-16/2754 -
The problem you're having is TDK dvd media is so crappy. Try using VERBATIM dvd media which is on sale right now at BEST BUY DVD-R/+ 50 pack spindle $12.99, sale ends today. If you still have those errors with the VERBATIM dvd media than as Baldrick suggested it is time for a new dvd burner.
I wish it were that simple but it is also doing it when I use my verbatim discs as well.
weird thing is last night I tried copying the DVD files created in shrink to a disc using nero itself, and it actually appears to have worked! -
You posted a link to newer 16X media. You have an old drive whose firmware doesn't have a write stategy for it. If you want to try other discs get older ones like Taiyo-Yuden 8Xs.
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 13:33 -
Errors on Shrink ripping latest hit dvd's
By bluzjamer in forum Authoring (DVD)Replies: 9Last Post: 6th Dec 2010, 00:13 -
Encoding errors, cannot burn DVD
By Surber in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2010, 11:55 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Error when dvd shrink trys to burn thru nero automatically
By themow in forum Video ConversionReplies: 1Last Post: 13th Oct 2007, 13:12
