recently I installed (and deinstalled) a few video converter programms and
aparently one of them installed or enabled the old classic media player v6
(which was not mentioned during installation!)
Now when I open a page where it has an embedded streaming like:
<EMBED Width="368" Height="322" SRC="http://url"></EMBED>
it opens (or tries to open) it in v6 but because it's a drm stream which
WMP11 had correctly been using it does not work.
So my question is: how do I disable this older version? I've unchecked all
extensions but there is no 'streaming-media' tab or anything...
Start WMP11 (usually in C:\Program Files\Windows Media Player\WMPlayer.exe), go to Tools -> Options -> File Types. Make sure "Windows Media File (ASF)" and "Windows Media Video (WMV)" are selected.
The browser MIME-type handlers could've been altered. Which browser are you using?
I think you can change them in Windows Explorer's 'File Types' dialog, but as I'm currently on a Vista system, I can't check XP's way of doing it. (That, and I can't remember the MIME designations for Windows Media streaming, either.
Don't forget, as well, that there are 'load' files for streaming media, like .asx files, so those need to be changed.)
If cameras add ten pounds, why would people want to eat them? -
I tried editing the registry but no luck.
It was changed in IE and also in Firefox, so I suspect it's something deeper.
I couldn't wait anymore cuz it was driving me nuts so I just reinstalled WMP11 over the existing copy of WMP11 and now it's back to normal again.
Thank god the DRM accounts that were active still work.
So... no real solution, but it's solved...
open avi with wmp/window media classic but no picture
By thesiuwolf in forum Newbie / General discussionsReplies: 4Last Post: 16th Aug 2010, 16:46 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 13th Jun 2009, 00:24 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Widescreen MPEG2 cropped to 4:3 in WMP 11 and Vista Media Center
By daemonic3 in forum Software PlayingReplies: 1Last Post: 26th Feb 2008, 00:01 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 00:18
