Results 1 to 13 of 13
    Jan 2007
    I joined 2 .avi files into 1 and then joined two other .avi files into 1. I then joined both of those into a single joined .avi file. I then tried to convert the joined file, which played correctly into a DVD VIDEO_TS and that's where it all came unglued. The original near 4 hours is down to 1 hour and 59 mins and it basically mixed it all up.
    Here is a dump of the log as it slugs through the joined .avi file. I'd like to point out again that the combined 4 avi files into one work perfectly. I'm running OSX 10.4.9 on a mac mini with 2 gigs of memory and plenty of disk space. Thank you for any help
    siberian
    Encoding started on Fri May 25 20:49:37 HST 2007
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    [NULL @ 0x54340c]hmm, seems the headers are not complete, trying to guess time_increment_bits
    [NULL @ 0x54340c]my guess is 2 bits
    [mpeg4 @ 0x54340c]hmm, seems the headers are not complete, trying to guess time_increment_bits
    [mpeg4 @ 0x54340c]my guess is 3 bits
    [mpeg4 @ 0x54340c]my guess is 2 bits
    [mpeg4 @ 0x54340c]my guess is 1 bits
    [mpeg4 @ 0x54340c]looks like this file was encoded with (divx4/(old)xvid/opendivx) -> forcing low_delay flag
    [mpeg4 @ 0x54340c]low_delay flag incorrectly, clearing it
    [mpeg4 @ 0x54340c]my guess is 11 bits
    [mpeg4 @ 0x54340c]Error, header damaged or not MPEG4 header (f_code=0)
    [mpeg4 @ 0x54340c]my guess is 10 bits
    [mpeg4 @ 0x54340c]my guess is 9 bits
    Input #0, avi, from '/Volumes/FW_Two/TV Downloads/The Tudors/The Tudors SE1E0104.avi':
    Duration: 03:39:57.7, start: 0.000000, bitrate: 894 kb/s
    Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 624x352
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
    Output #0, dvd, to '/Volumes/FW_Two/TV Downloads/The Tudors/The Tudors SE1E0104.avi.ff.mpg':
    Stream #0.0, 23.98 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-5, 2994 kb/s
    Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    [mpeg4 @ 0x54340c]warning: first frame is no keyframe
    [mpeg4 @ 0x54340c]ac-tex damaged at 3 0
    [mpeg4 @ 0x54340c]Error at MB: 3
    [mpeg4 @ 0x54340c]marker does not match f_code
    [mpeg4 @ 0x54340c]concealing 858 DC, 858 AC, 858 MV errors
    [mpeg4 @ 0x54340c]Error at MB: 2
    [mpeg4 @ 0x54340c]header damaged
    Error while decoding stream #0.0
    [mpeg4 @ 0x54340c]ac-tex damaged at 0 0
    [mpeg4 @ 0x54340c]Error at MB: 0
    [mpeg4 @ 0x54340c]my guess is 8 bits
    [mpeg4 @ 0x54340c]cbpc damaged at 0 0
    [mpeg4 @ 0x54340c]my guess is 7 bits
    [mpeg4 @ 0x54340c]my guess is 6 bits
    [mpeg4 @ 0x54340c]concealing 793 DC, 793 AC, 793 MV errors
    [mpeg4 @ 0x54340c]concealing 795 DC, 795 AC, 795 MV errors
    [mpeg4 @ 0x54340c]concealing 798 DC, 798 AC, 798 MV errors
    [mpeg4 @ 0x54340c]concealing 796 DC, 796 AC, 796 MV errors
    [mpeg4 @ 0x54340c]ac-tex damaged at 30 0
    [mpeg4 @ 0x54340c]Error at MB: 30
    [mpeg4 @ 0x54340c]concealing 827 DC, 827 AC, 827 MV errors
    [mpeg4 @ 0x54340c]ac-tex damaged at 2 1
    [mpeg4 @ 0x54340c]Error at MB: 42
    [mpeg4 @ 0x54340c]concealing 783 DC, 783 AC, 783 MV errors
    [mpeg4 @ 0x54340c]illegal MB_type
    [mpeg4 @ 0x54340c]Error at MB: 5
    [mpeg4 @ 0x54340c]ac-tex damaged at 12 0
    [mpeg4 @ 0x54340c]Error at MB: 12
    [mpeg4 @ 0x54340c]Error at MB: 88
    [mpeg4 @ 0x54340c]1. marker bit missing in 3. esc
    [mpeg4 @ 0x54340c]Error at MB: 148
    [mpeg4 @ 0x54340c]ac-tex damaged at 10 1
    [mpeg4 @ 0x54340c]Error at MB: 50
    [mpeg4 @ 0x54340c]Error at MB: 16
    [mpeg4 @ 0x54340c]ac-tex damaged at 29 0
    [mpeg4 @ 0x54340c]Error at MB: 29
    [mpeg4 @ 0x54340c]Error at MB: 9
    [mpeg4 @ 0x54340c]Error at MB: 58
    [mpeg4 @ 0x54340c]my guess is 4 bits
    [mpeg4 @ 0x54340c]Error at MB: 214
    [mpeg4 @ 0x54340c]concealing 706 DC, 706 AC, 706 MV errors
    [mpeg4 @ 0x54340c]Error at MB: 196
    [mpeg4 @ 0x54340c]cbpc damaged at 27 14
    [mpeg4 @ 0x54340c]Error at MB: 587
    [mpeg4 @ 0x54340c]concealing 407 DC, 407 AC, 407 MV errors
    The Best long distance runners eat raw meat, run naked and sleep in the snow
  2. Hi,
    Have you try to join your AVI files with SimpleMovieX ?
    Regards, BJ
    Jan 2007
    Hi AeroQ,
    No I haven't. But it's not the joining that seems to be the problem as I am able to see the result with no problem as an .avi file. It's only when I try to convert the 1.3 gig joined .avi file to a DVD Video_Ts file that said problem arises. Thanx
    siberian
  4. Did you join the AVIs with ffmpegX ? If so, I'd advise trying again with D-Vision.
    Jan 2007
    Yes, AVIs were joined via ffmpegx. So if I understand you correctly FFOOKY, I shoudl join via ffmpegx and convert via D-Vision? TIA
    siberian
  6. Nope, join 'em with D-Vision...there's a recognised bug with ffmpegX in this regard.
    Jan 2007
    Let me ask you this, how do I create a VIDEO_TS output from the avi files in D-Vision? I looked in the tools section but although various formats were available I didn't see TS or MPEG2 as output. Did I miss it? TIA
    siberian
  8. You can't use D-Vision for that part, just for the initial joining. I'd personally use VisualHub for the final AVI->VIDEO_TS conversion though ffmpegX is as good/better.
    Jan 2007
    But see that's what confuses me. The joined AVIs via ffmpegx when viewed with say RealPlayer works great. There's no problem with it whatsover and since you seem to recommend ffmpegx to convert it into a TS, where is the problem (I mean other than it doesn't work)? Would D-Vision cure a non-viewable error (as an AVI) via RealPlayer which could then be used via ffmpegx to convert? Sorry for being obtuse here. TIA
    siberian
  10. No need to be sorry I've no idea why the joined file might play fine in Real Player and still give problems when you try to convert it but I'd still recommend you try joining again with D-Vision (using the default avimerge option) and see if that will convert properly.
    Jan 2007
    I guess some things are just taken on faith , I'll try that. Thanx again and have a great weekend!
    siberian
  12. Let us know how things turn out. Cheers now.
    Jan 2007
    Will do, must be time for bed over in the "old country"
    Thanx again for your help!
    siberian
