The program u just need to use is Windows XP
This lesson will teach u that ALL video convertin software are crap wit realmedia
First GO to control panel
Click folder options in appearance and themes
Uncheck hide extensions for known files
Go to the rmvb file your going to convert
rename the rmvb to avi
And PRESSTO the conversion is DONE!!
WARNING!! You must install realplayer or RealAlternative Inorder for it to work on other media players!
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
Closed Thread
Possibly the single dumbest conversion post I have ever seen. Changing the extension does not in any way convert the video. The fact that you must then have Real Alternative installed to play the video shows this.
For a first post, you have managed to set yourself a fairly low personal benchmark. Let's see if you can better it in the future.Read my blog here.
How to convert RM/RMVB to AVI or MPEG1/2
By kschang in forum User guidesReplies: 112Last Post: 11th Feb 2012, 19:56 -
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 04:09 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 10:29 -
What program will convert AVI to .RMVB quickly?
By Salva Veritate in forum Video ConversionReplies: 8Last Post: 13th Aug 2007, 21:15 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 17:41
