hi everyone
i hope u can help
i have just bought a pioneer dvd model DV-393
when i set up i selected progressive scan, not realising that my lcd tv (AOC 32 INCH) did not have progressive scan!!
Now i cant get the dvd menu to come up so i can chgange it back.
No menu comes up at all now after i selected progressive scan.
can anyone help
or is that a fault of the pioneer??
thank you all
kevin
Call Pioneer. They will know how to reset it.Originally Posted by kbm
If all else fails unplug it overnight so it resets itself when next plugged in. They are designed to hold settings several hours through power failures. -
hi
thanks for that, i will turn it off now and leave it overnight to try it.
once again thanks
if anyone has some info i will check back later
cheers kev -
hi
tried turning off for hours
dvd is stil locked on progressive and
i cant get to bring the dvd menu up on the lcd tv
as nothing happens when i select "home menu"
which is the install menu to get going
hope u can heklp
cheers kev -
http://www.pioneerelectronics.com/vgn/images/portal/cit_11221/310797954DV393SOperating...structions.pdf
Read thoroughly - page 14 may be the reset.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
BTW: If you connect your TV up via component (RCA) jacks, you might be able to view the menu.
I've had one earlier Pioneer that did the same thing via pressing the wrong button on the remote, as well as a cheapo Colby: I've always been able to change connections and restore the defaults.;/ l ,[____], Its a Jeep thing,
Resetting the player
Use this procedure to reset all the player’s
settings to the factory default.
1 Switch the player into standby.
2 Using the front panel buttons, hold
down the
(stop) button and press
STANDBY/ON to switch the player back
on.
All the player’s settings are now reset.;/ l ,[____], Its a Jeep thing,
hi classfour,
just wanted to let u know you were spot on, once i bought the component RGB cables and plugged them in, i could access the menu on the tv screen thru the DVD player menu button
Also as you said you can reset to fault setting by pushing "STANDBY POWER" and"FAST REWIND" at the same time which is what the menu said when it was showing up before and also on the page 14 you mentioned.
So a huge thank you to you for solving this for me, even when i took it back to the shop today, the alll the salesmen had no idea and had never seen this happen before.
it wasnt untill we plugged in the CMP cable that we could see the menu again.
Do you know why this is, because it looks like a software bug to me, but im no expert thats for sure.
Once again thank you very much
cheers kev
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 07:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
I am confused about the DTS playing capability of my Pioneer DV-393-S...
By oleglelchuk in forum DVD & Blu-ray PlayersReplies: 7Last Post: 18th Apr 2008, 22:34 -
Pioneer DVD DV-393 Progessive Scan Locked - Problem Solved
By kbm in forum DVD RippingReplies: 2Last Post: 27th May 2007, 18:52 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 20:58
