    Mar 2005
    spain
    Hi!
    I have 2 ts_folders of the same movie.
    One of these folders has subs in swedish and danish,the other english and french.
    Would it be possible to take the swedish subs and burn them to the ts_folder with the english and french subs?
    Where are the subs located in the ts folder?
    Thx for any help.
  2. Would it be possible to take the swedish subs and burn them to the ts_folder with the english and french subs?
    Yes.
    In the vobs. You can get them by using PGCDemux on the IFO containing the video. You'll get them in SUP format ready to be added to the other video (which will also have to be demuxed) using any authoring app that supports SUP format subs (Muxman, IFOEdit, ReJig, GUI4DVDAuthor).
    Mar 2005
    spain
    thx for the quick reply!
    In the ts folder,is there a specific file(vob) that contains the subs?
    Apr 2004
    Miskatonic U
    The same VOBs as the title itself. List what you have and we can tell you the title, but if it is a feature it is usually the biggest titleset (i.e. the one with the most VOBs in it)
    Read my blog here.
