I have recently experienced difficulty with my Sony DVD RW DRU-830A burner. I have used Sony DVDs to record but the colors of the end product is distorted when viewed on a DVD/TV. I have used Memorex DVDs with the same result thinking that the Sony DVDs might be inferior. However, in researching the subject, I realize that the Sony DVD (Mfr ID: Sony16D1) should be a reliable DVD and superior to the Memorex. Can anyone enlighten me as to what the problem might be? I certain appreciate the help!
I would suspect the source data, not the hardware. Bad/cheap media typically causes stuttering/skipping/lockups because the data is corrupted. It shouldn't cause distorted video.
What is your video source? How are you processing it? How are you authoring it?Google is your Friend
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
Sony DRu 840 dvd RW Tray won't stay closed
By scustalow in forum ComputerReplies: 1Last Post: 30th Apr 2008, 12:39 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
