    May 2007
    Hello,
    I purchased a Coby 224, knowing from a friend the posted region hack works. Unfortunately, it didn't! This is apparently a 224ss, not the 224m or 224. Does anyone have any leads on how to hack this, or am I stuck with it.
    Jul 2007
    Hi, I received the following info from Coby tech support:
    Region Code Change for Coby DVD-224SS
    NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
    DVD224SS
    1. Open the DVD tray
    2. Press STOP button on the remote control
    3. Press 70
    4. Press MENU
    5. Use the numeric keypad to select your region code number (0 – 6).
    OR
    DVD224 (224SS)
    2. Press STOP button of remote control
    3. Press the digit number buttons “2008” of remote control.
    4. Press MENU
    Region code will appear, select your region code number.
    Jul 2008
    Thank you so much! The first set of instruction worked on my Coby DVD-224SS.
    DVD224SS
    3. Press 70
    4. Press MENU
    6. Close tray
