i was just wondering (might be a stupid question) but , is there anyway of putting the scandata.dat file in nero like the prog its self because sometimes i forget i think it would be alot easyer if it was allready there. prog hack reg hack ? perhaps,. any feedback would be apperciated
---------- thanks loser
I understand your problem as it has happened to me as well, that I forget to put my selfmade Scandata.dat's in the EXT directory.
As Nero only generates a Scandata.dat for VCD's and not SVCD's (oddly enough in some DVD Players this works), so to remind me I have made sub-directories under my main movie directory. This way I "usually" see it and remember. I don't know if this would be any help to you.
The main problem however is that if you use the simple "SCAN_VCD"-Scandata.dat you can FF/FREW but you can't go/to or search. I have eliminated this problem by generating and extracting Scandata.dat's from VCDImagerGui for clips lasting 20,25,30,35,40,45,50 and 55mins. All depending on how long my clip is, I include from a sub-directory (called "45min" for example) the 45min scandata.dat.
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 07:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 13:38 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 23:53 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23
