I have TMGEnc Authoring 1.5 and have the authored DVD video and audio folders my c drive, but when I use the TMPgen burning tool the middle of the video gets blocky and jumps. I could be a hardware track creation problem or maybe the burning tool?
Anyway, I want to create a DVD using ready folders. Can I just burn the off window explorer to the DVD disk, or do I need to use some other burning tool?
And if I need to use another burning tool, any recommedation on any freeware or trial that I can down load?
Results 1 to 9 of 9
ImgBurn burns images - you'd have to create an image from the dvd folders. Folder2iso may do the job for you.
I'd try opening the dvd folder with PowerDVD if it's on the machine.
If there is blockiness in the playback, then you know for certain it's an authoring problem.
You didn't say if this happened on multiple copies of the same DVD???;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
The recent versions of ImgBurn can burn directly from the DVD folders, using "Build" mode - no need to create an intermediate ISO file (unless you want one, of courseOriginally Posted by classfour
Guide here (although it's pretty straight-forward):
http://forum.imgburn.com/index.php?showtopic=1779
Jim -
can this same kind a video folder burning be done with the Vista windows explorer? I'm trying to find the easies way.
No idea, I don't have Vista. Why don't you TRY IT and see what happens?Originally Posted by yogart
Answered multiple times already.I'm trying to find the easies way.
Jim
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
Is there any tool for me??
By kemcel in forum Video Streaming DownloadingReplies: 1Last Post: 10th Jul 2008, 00:16 -
Which tool ?
By NICEBUD in forum Authoring (DVD)Replies: 7Last Post: 17th Jul 2007, 15:06 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19 -
burning tool question.
By cowboysroy31 in forum Newbie / General discussionsReplies: 1Last Post: 5th Jun 2007, 00:08
