I just found this all-singing and all-dancing video file converter which is FREE!! but I can't find a 'GO' button.I'm converting a quicktime mp4 file into dvd vobs. It loads ok but doesn't start.
Anyone got any ideas. If you haven't used it before go check it out at www.erightsoft.com.
Appreciate some help here guys.
Ness
Cheers and Be Lucky
What resolution is your desktop set to? SUPER requires it to be set over 800x600, otherwise, you may not see all the buttons at the bottom of the window. If you do have you do have the desktop at 800x600, you'll need to set it to a higher resolution and reboot, before using SUPER.
super video converter portable
By jamespoo in forum Off topicReplies: 3Last Post: 2nd Mar 2011, 03:25 -
Super converter shut down.
By dfisher052 in forum Video ConversionReplies: 0Last Post: 21st Mar 2009, 10:49 -
Encoders using Super Converter
By Szymus in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 02:19 -
Alternative to super video converter
By a1i3n777 in forum Video ConversionReplies: 6Last Post: 8th Nov 2008, 06:33 -
SUPER v2007.build.22 (Mar 14, 2007)... does anyone have it?
By jamescardenas07 in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 23:10
