Hi - I was wondering if anyone uses the AVT-8710 and what they thought of it. Mainly, does it successfully remove Macrovision from VHS tapes? In some scenarios, I'm plagued by the kind that dims and brightens the picture randomly. Also, since it only has video in/out that means my audio coming from the VCR is going through one less contraption - I currently use JVC SVHS > Canopus ADVC-110 > Fire Wire > PC and use Vegas 7.0 for capture. I would imagine there will be a frame or two audio sync issue. I think Vegas can compensate for this.
Is the TBC 1000 any better, and if so, why? I know the TBC 1000 has RCA audio in/out too. It costs twice as much.
OK, so maybe no one has ever used that.
Here's some cheaper alternatives:
There's the DVD Red Pro:
http://www.xdimax.com/dvd/dvdredpro.html
Clear Pix:
http://www.checkhere22.com/stabilizer/
And the Video Magic/Ultra:
http://www.stardevelopment.com/
Anyone ever use any of these? -
There are some extensive threads here comparing the merits of these -- check the Forum archives, keying on words like "TBC" or "AVT". The TBC 1000 is pricey at list, but they do turn up on Ebay used, selling for as low as $250. (The AVT turns up there much less often.) I don't believe there are any moving parts at all in these units, so as long as they weren't electrically fried or dropped onto a hard surface, there should be very little to go wrong with them. The TBC 1000 looks to be built quite a bit more ruggedly than the AVT, so far as that goes. It does seem to have solved the main problem I got it for, though I haven't had much time to pursue that project since I got mine.Originally Posted by hip_school_preppieLooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
I own one of these, and if you search the forum, you'll see it mentioned hundreds of times, discussed in various threads. I've compared TBCs a few times, as have others.
There is also a whole thread dedicated to "copy protection" and other video errors that trip up transfers. It's a sticky in the restoration forum.Want my help? Ask here! (not via PM!)
Thanks folks!
I'm going to ive this one a try...
Clear Pix:
AVT-8710 owners, what settings do you use?
By myoung08 in forum Capturing and VCRReplies: 5Last Post: 27th Jul 2010, 23:10 -
Problems capturing with AVT-8710
By Tafflad in forum Capturing and VCRReplies: 1Last Post: 9th Feb 2010, 07:45 -
AVToolbox AVT-8710 TBC
By maeks84 in forum RestorationReplies: 3Last Post: 28th Apr 2008, 00:37 -
Help with AVT-8710 TBC
By Reniamatic in forum RestorationReplies: 2Last Post: 17th Sep 2007, 15:26 -
Panasonic e80h and the AVT-8710
By rmmd in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Sep 2007, 13:03
