Hi
I have been having a look at a CVCD template. I have noticed that its MPEG-1 with VBR.
Can more be gained from a DivX conversion by specifying MPEG-2 for improved compression? I have never actually done a comparison and hence am unsure if MPEG-2 compression is significantly better than MPEG-1.
Also I'm interested if 2-Pass VBR would give similar or better results.
Kind Regards
Darren![]()
MPEG2 will make it even less compatible, and it's also more optimized for high bitrates, while MPEG1 is better for low bitrates, although you get more options using MPEG2
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
