How do you rip a dvd using ImgBurn to one big Vob file?
Dave
Results 1 to 11 of 11
Dave A Smith
Maybe just me, but I'm wondering why you would want just one big VOB file? You can use VOB2MPG to make one big MPEG file out of a decrypted DVD easily enough. That would give you a format that is more commonly used for editing. Since a VOB is a MPEG (Among other things), even for archiving it would seem a better choice.
If you try to run that one large VOB through a authoring program, it will just get cut up in to standard 1GB VOBs anyway.
And welcome to our forums.
There are lots of reason's to, i do it at least a few times a week, also to demux into elementary streams, M2V, AC3, chapters file, ect. ect.Originally Posted by redwudz
Why rip then merge back together when you can do it in one step from the start
Can't get much easier than that 8) -
Looks like practically no one gave you any info that you can use. Yes, Imgburn can read an UNPROTECTED dvd into 1 big VOB file. From the tools menu, select settings and click on the READ tab. Inthe READ tab you will see a drop down menu next to file splitting. Select "None". This will allow you to decrypt your UNPROTECTED dvd into 1 big VOB file.
Bobk wrote
"Actually IMGburn does rip. It just doesn't rip protected DVDs."
Then I guess the other posters who recommended DVDD and Smartripper were wrong to assume what the OP meant... except you of course...." Who needs Google, my wife knows everything" -
Or if the files are already on your hard drive, you can use DVD Shrink to produce one VOB.
Extracted VOB too big...
By pinetop in forum Newbie / General discussionsReplies: 7Last Post: 31st Dec 2009, 13:33 -
Dvd with subtitles and Audio tracks in one big vob file help converting
By jimbobob84 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2009, 02:09 -
395MB folder to big to fit on 700MB CD in ImgBurn
By happydog500 in forum AudioReplies: 30Last Post: 30th Jul 2008, 12:58 -
DVD to one big VOB ?
By rindless in forum DVD RippingReplies: 5Last Post: 19th May 2007, 04:42
