Well i made this 12 minute long DVD in premiere and i also exported it into an mpg. I wated it to go on the web so i Opened FLV encoder that came with flash. I converted it and the video is fliped vertically. whats wrong. is it the codec?
Thanks!
Austin Condiff
In which player are you attempting to play the FLV video? You may need to install an FLV Splitter.
Does the FLV play properly in players like mplayer or VLC, if you have them installed?If cameras add ten pounds, why would people want to eat them? -
well in the Flash Video encoder, it has a video preview and it is flipped vertically. When it is done encoding it is still flipped. Then I've downloaded the Riva FLV encoder and tried to encode my mpg using that and it said that there was an error encoding the FLV. I try other mpg's in both programs and they do the same thing. It sounds like a codec problem but im not sure.
What do you think?
Thanks!
Austin -
It strange...Originally Posted by InfinitySquared
Riva FLV encoder not use external codecs or filters.
This is GUI for FFmpeg and FLVTool2.
I'm check conversion MPEG-1 and MPEG-2 files - without problems.
Maybe try MediaCoder or SUPER? -
I would export to avi in premiere instead and convert it to flv with the flash video encoder(it's better than riva flv encoder/ffmpeg ).
well it will take a whole day to export to an avi. is there any way that i can correct this problem?
also, its an 800 MB file. That might be an issue with riva. but im not sure thats the case with Flash Video Encoder. -
InfinitySquared, it's already taken a whole day to get an answer that you don't like, so you still don't have anything. If you had done the Export-->AVI, you'd be done by now.
Scot -
very true, but it still irritates me that i can no longer encode mpegs.
Need help with codec for .flv playback
By 2ndHandGizmo in forum Software PlayingReplies: 2Last Post: 2nd Mar 2012, 10:53 -
convert .flv with codec H264
By Ogilvy in forum Video ConversionReplies: 2Last Post: 5th Aug 2009, 08:19 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Converting MOV to FLV - codec problems
By communique in forum ffmpegX general discussionReplies: 5Last Post: 13th Jun 2008, 14:58 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09
