  1. Member Crazyj32's Avatar
    Apr 2006
    For some reason I cannot use it in conjuction with nerovision 7, 6, nor videomach even though it is listed as one of the output codecs and Im able to tweak the ffdshow dll via the nv and videomach.
    My goal is to use ffdshow to make 2-pass flv's for youtube, and I have enabled livebec(sp?) for flv1.
    Helpppp!
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Are you using one of the more recent versions of ffdshow? They have configuration options to only allow ffdshow to be used with certain programs, or to exclude certain programs from using it at all (just in case there are compatibility issues).
    From the Video Decoder Configuration, highlight "DirectShow control" in the window on the left. You should see a window that looks like the one below. You can add the applications to the "Use ffdshow only in:" list, or uncheck the checkbox next to it, if you feel confident it won't have any conflicts with any other programs or codecs.
    You'll need to do the same with the Audio Decoder Configuration.
  3. Member Crazyj32's Avatar
    Apr 2006
    Hmmmm, I dont have the 'directshow controll' tab but I got this off of videohelp about a day ago.
    And another thing, what your showing me looks like input settings, my problem is with the output. Nerovision and videomach have no problem loading flvs, the problem arises when I try to use ffdshow to encode the altered video.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    There's a number of different versions (most of them are nightly builds, now, I guess), and each may have the settings in a different place. I think the one on one of my Win98 towers has it under "Info & debug".
    Give it a try and see if it works, at any rate. As far as I know, it should apply to both encoding and decoding, if indeed your build offers it, even though it's set in the Decoder options. For all I know, they're still working on the best place to put options.
