I'm having trouble with the SUPER video converting program. It seems to have a decent amount of options, and can convert to and from a pretty good variety of formats, plus its freeware, which should make it a great program...
But for some reason, it can't convert anything that my psp will play. I have PSP Mp4 selected as the output format (on the top-left corner), and it doesnt work, regardless of codec (h264, MPEG-4), bitrate, resolution..... it just doesnt work.
it will convert a video. the video plays perfectly fine in MPC and quicktime. but my psp just shows it as unsupported, whether i put it in the VIDEO folder or the MP_ROOT/100ANV01 folder.
Anyone else having problems with this program? If you do have it working properly, please tell me what settings i should change to make it work properly...
	asdf
  SUPER to convert from DVD to Sony PSP?By snafubaby in forum Video ConversionReplies: 2Last Post: 25th Aug 2008, 05:16
  rmvb to psp (h.264 avc) on SUPER not okay?By savvyguy in forum Video ConversionReplies: 4Last Post: 8th Aug 2008, 11:30
  Converting with SUPER for PSPBy Nitro89 in forum Video ConversionReplies: 10Last Post: 3rd Mar 2008, 14:37
  Converting from DVD to PSP with SUPER, wrong languageBy supraman215 in forum DVD RippingReplies: 2Last Post: 12th Dec 2007, 10:50
  Best PSP Converter?By Nitro89 in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 09:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
