In Sony DVD Architect 4.0, when I burn a DVD containing a playlist of single video titles (no chapters included) and, after selecting the playlist, use the "next" (skip) button to advance to a subsequent title in the playlist and watch this title until the end, the DVD continues playing the title that would have followed the title in which I selected the next button, instead of the title next in line. Perhaps this makes it easier to understand:
start playlist
clip 1->next->next->next
clip 4...finish
clip 2
clip 3->next->next->next->next->next
clip 8....finish
clip 4
etc.
It seems the playlist does not track title advance and only advances to the next title in the playlist if it played in it's interity. I could use a trick, by adding a chapter right beofre the end of each title, but that would be a lot of work and I am wondering if there are any other ways to achieve my goal.
Dosent appear to be much fun , dose it , and I cant tell you where the issue may have come from , even through I have sony dvd architect 4.0. , but there are two possibilities that may have happened to cause the issue .
You have updated it ?
Grab pgcedit , load up your dvd compiled project on the hard drive , and check this out .
https://forum.videohelp.com/topic322350.html
You need to readjust those nav commands so they reflect how you want it to playback , and playlists can drive you nutts if your not carefull .
You want to :
Play clip 1 , hit remote , skip 2 , skip 3 , skip 4 , play 5 , play 6 , skip 7 , play 8 .
Return to menu at end I suppose , without it playing those skipped clips .
Am I right ?
Hmm , seems theres a continous issue .
Load your project into pgcedit , and take a snap shot of what it shows in the left pane , we will know whats going on then .
Title skip in MultiAVCHD
By maniachiavelli in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jun 2012, 22:29 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
DVD Architect pro 5: problem with playlist, brancing and next (skip) button
By alfini in forum Authoring (DVD)Replies: 0Last Post: 25th Oct 2010, 07:28 -
Default Chapter title - DVD Architect 5.0
By KayAt in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 05:11 -
Faulty Sony DW-U18A DVD Burner
By Sakuya in forum DVD & Blu-ray WritersReplies: 31Last Post: 3rd Nov 2007, 03:16
