Hello
I have a avi file in some other language with 29.97fps. I found the same file in avi format with english audio but horrible video ,fps 23.976. So, I extracted the english audio from second file and saved as wav and multiplexed it with first video using virtual dub. But now the audio has gone totally out of sync at all places , at some places by 5 minutes. I sync it at one place but the rest of the file still is out of sync.
How do I fix the audio sync.
Mike
Did you check in VD that the audio and video files are the same length? I suspect one of them may have been edited at some point if the sync error changes.
I use VD Mod, as it seems to handle audio better. You could also be dealing with VBR audio, though VD should have told you that.
Adding A Second Audio Track To A DVD
By tooonami in forum Authoring (DVD)Replies: 1Last Post: 14th Feb 2011, 07:56 -
Adding a second audio track to a DVD-R
By danielmak in forum MacReplies: 1Last Post: 30th May 2010, 22:31 -
By DeathStalker77 in forum Authoring (DVD)Replies: 0Last Post: 11th Aug 2009, 02:16 -
Adding new audio track to avi file
By skaleton in forum AudioReplies: 5Last Post: 11th Apr 2008, 14:29 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 18:45
