No, that's what they made Popcorn for. But Popcorn is now included with the current version of Toast. I still use T6. DVD2OneX also known as DetoX is much better and faster at compressing a folder to fit, so you can burn it as data>udf in Toast.
If you do a main feature rip with MTR most of the time it will fit one disc anyway.
Popcorn2 is $50 http://www.roxio.com/enu/products/popcorn/standard/overview.html
Unless you have a G3 and can't use later versions of Toast then buying Toast 7 or 8 or DetoX is a better deal in my opinion. -
Thanks, I have DETOX 2.1.1 but if does not allow you to customize menus in the Join Vob mode like Toast will do in the Video mode. It's that I can't seem to get Toast 6.1.1 to do the job. I'm trying to put a favorite Twilight Zone together by joining various episodes from several discs onto one SL disc.Originally Posted by dnix71
beefer -
do an end run around it.
Get MpegStreamclip
(along with the QT Mpeg-2 component)
open your .VOBs there, save out as
QT .mov files (using Photo-JpegA or
3ivx d45R1 at its highest quality setting)
and then author in toast using the Video-->DVD
selection.
MpegStreamclip will make the files slightly smaller,
and Toast will compress ( in authoring) to fit them
onto a SL disc, and you get your menus. If the disc
ends up being slightly bigger than 4.37GB, then use DETOX
to shrink slightly to fit SL, and you'll still have great quality."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Toast 7
By JordanBlake in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2010, 15:07 -
iDVD / Toast Compression No Longer Working?
By toxicquack in forum MacReplies: 3Last Post: 26th Jul 2009, 11:57 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 22:45 -
Toast Demo
By andredanton in forum MacReplies: 2Last Post: 13th Feb 2008, 18:29 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 06:00
